mystang
Need help with diagnosis.
Little back story, I have replaced every single gasket or seal on this engine except the head gaskets. I have had everything apart and have put it back together. Good news is the engine dosent leak anymore, bad news is when I try to time the engine. with ETC disconnected at 6 degrees BTC, the car idles up to aroud 1200 to 1500 rpm. If I advance to ATC it will idle down, but I am not able to see the timing mark? ;help Also after a few minutes the headers start to glow cherry red no matter how i set the timing.
Secondly, it smells a bit rich and check engine light is on. after pulling the codes i have the normal #12, then #14 (Engine coolant Temp (ECT) sensor- Circuit low or open circuit. #33 (Map sensor signal voltage ouf of range, high) I believe that the headers are glowing because of alot of fuel in the exhaust, and the map sensor "issue" could be part of it? Also #42 (Electronic spark timing (EST) Circuit grounded or ignitinon control (IC) circuit grounded or faulty bypass line. (Is #42 not expected when you have to pull the bypass line loose to do the timing?)
I have not had a chance to check map sensor or incoming voltages. The coolant sensor could be messed up when I was cleaning the lower intake manifold
. but the map that one has me thrown for a loop as i have the vaccum line plugged into the manifold and I even replaced the vac line, but changed it back to the old one after the codes?
Is there a fuse for this item or items.
. but the map that one has me thrown for a loop as i have the vaccum line plugged into the manifold and I even replaced the vac line, but changed it back to the old one after the codes?Is there a fuse for this item or items.
