Yeah, with the right valve and the advance, it looked to bring it more in line. Thanks for figuring that one out. This combo reaches back around 6-7 years ago, I think. There's no telling what they left out of the article back then. I can't believe that I forgot what I read about advancing the camshaft. I must be losing brain cells or something. :crazy
The next thing that I want to try is the set-up run by the guys over at Crank&Chrome. I'll try to run down all the specs and see how close that one comes up on the simulation. The only thing would be comparing final ratings, because of the wheel dyno they used. I guess I can just use somewhere between 10-20% drivetrain loss as an equalizer.
After that I want to see how smaller valves, like the ones I got, affect hp and torque. This is important to me as it'll directly affect my wallet. I don't think I'll be able to spring for aluminum heads, but I'm willing to do some porting on the ones I got. Again, it all depends on what the $$$ figure will be.
I'll be concentrating on camshaft specs mostly from Lunati, because the information is on the web. When you said that you just needed a cam number, does that go for every cam for any manufacturer?
Anyways, I'll do that stuff later today. I'm taking a break from replacing rear rotors on a BMW right now. Man, those suckers were stuck on tight. Nothing that a sledgehammer and a pickle fork couldn't take care of, though. :L
--Bullitt
