Well we can always start a thread about high flow water pumps.
My only issue with high flow pumps has to do with the bypass hole. The bypass hole is the third hole in the right side of the block. This hole goes through the pump and into the inlet area of the pump. This allows water to bypass the radiator and flow back through the motor. The only purpose that it serves is to warm the engine up faster. After the engine is warm all the bypass does is defeat all of your efforts at cooling your motor. Most high flow pumps block the bypass hole off. I would rather have the faster warmup in the winter time. Blocking the bypass also increases the water pressure I'm told, though I haven't tried to measure it. Prior to buying a high flow pump I would insist on knowing if the bypass was blocked.
I'm too lazy to have a summer and a winter (yes, I do drive on nice days in the winter) water pump and change them with the seasons. My homemade fix has been to tap the water pump bypass hole and fit a plug in the hole. The plug was then drilled through the center with a 1/4 inch drill bit to allow some water passage, but not the 1/2 inch diameter hole amount.
How important is your heater to you? Without the bypass it will be slow to warm up. If you live in the deep south that may not be a problem.
