M
Michael 427
This maybe an old thread, but my 427-400HP was never changed over to burn unleaded fuel any suggestions on types of fuel or additives to use instead of going through the expense to have heads done.
Michael 427 said:This maybe an old thread, but my 427-400HP was never changed over to burn unleaded fuel any suggestions on types of fuel or additives to use instead of going through the expense to have heads done.
JohnZ said:99% of the "miracle octane additives" you find in parts stores are LOADED with ethyl alcohol, which will eat conventional cork and rubber gaskets and seals, and also eats the plating off the inside of your float bowls; alcohol also attracts water, which then corrodes the unprotected inside of the carb.
