toobroketoretire
Banned
Last summer I installed a set of higher compression pistons and rings from Summit Racing and ever since my 454" has burned a quart of oil every 400 miles. In the past years I have always used Hastings rings with VERY good results so I'm wondering if these Summit Racing rings were made in China and have low oil ring tension. The high oil consumption bothers me but as oil is so cheap I hate the thought of tearing it apart just to install a set of Hastings rings. I have Perfect Circle Teflon seals on all of the valve guides and the chrome-stem valves are new and the guides are barely worn so I'm sure it's the oil rings that are causing the high oil consumption. I am hoping the oil rings will eventually seat (better) but with about 40,000 miles on it they're sure taking their sweet time.
Last winter I had noticed it produced some blue smoke during it's warm up so I lapped the rings using a 50/50 mixture of Bon-Ami and ATF. I poured 2 ounces of the sloppy mixture into each of the cylinders (with the spark plugs removed) then spun it over about 1000 revolutions. That completely stopped the blue smoke during it's warm up but not the high oil consumption so I'm sure it's just low oil ring tension. My spark plugs don't show any signs of oil burning after an extended drive BUT they do look a little crummy during my day-to-day driving.
Have any of you guys used Summit Racing rings and ended up with an oil burner?
