high speed on fan is gone...
ZRGator
Gone but not forgotten
West Friendship, MD
1993 40th ZR1, 1967 Red 427/400 coupe
The high speed on my fan is shot. Particularly bothersome when trying to crank up the a/c. I can't seem to find an original replacement relay for this..any help? Thanks, guys. Also, where might this problem be located?
Is the ground wire for the relay intact? The relay is attached to the fiberglass evaporator case, and has a separate black ground wire that goes under one of the two attaching screws.
Thanks for the hint, John, I'll go check it when I get home tomorrow night.
As posted above, the high speed A/C blower relay is fed directly from the horn relay screw terminal by a red wire with an in-line plastic fuseholder with a 30-amp fuse in it; check that wire for power at the relay connector - it should show 12 volts all the time, key on or off.
