eoseitz
I know there are a lot of discussions about the heaters on here, but I can't seem to find any detailed steps to take to test what has failed in my car. I just bought a blower motor resistor. I'm not sure if that's what's wrong but I thought it may be a good start.
The blower works in off, low and medium. When I switch to high speed it shuts off again. How do you test the high speed setting on the switch? Also how do you test the relay to see if it's working? I also heard there is an inline fuse and a fuse in the fuse box. That seems redundant but if there is, where is the inline fuse located.
Thanks for any help.
