G
goertz
ok, in traking down my various vaccuum leaks, i found the strangest thing i've ever seen in my 20+ years of tinkering with GM cars. there is a vaccuum leak from the master cyl. NOT THE BOOSTER, the master. on the bottom of the master, near the flange, there is a 3/8 horizontal hole that goes through the casting, and a ton of vaccuum is leaking through there. so i figure, i'll put a bolt through the hole, to see if that fixes it. well the vaccuum leak stops, but so do the power brakes. anyone else ever experienced this? maybe the booster is bad, and leaking through this hole. maybe the hole is some sort of fluid drain just in case something got into the booster? what gives?
