Sylvania Silverstar Comments
Just FYI, I got an email back from Sylvania when I asked about the difference between the Silverstar (ST) and the XtraVision (XV) models.
"The SilverStar is the brightest and whitest product that we manufacture currently in a replacement halogen. The SilverStars, at 4000 degrees Kelvin, have the highest street legal color temperature available through Sylvania and are comparable to HID lighting. The SilverStar's higher color temperature provides a crisper white appearance and offers a redesigned coil to direct the light into more usable light in the foreground. This whiter light is better at picking up reflective materials such as animals' eyes, and road signs. And, this does not translate into a "hotter" bulb, it's the same heat temperature as all the halogens. The SilverStars are a performance, premium halogen that has a shorter life span than the standard version. The shorter life span is directly related to the performance nature of the lamps. The blue absorption coating on the glass contributes to the crisp white light emitted, but also traps heat inside the capsule, causing the filament to burn out more quickly, thus decreasing the life. As with most high performance products, there is a trade-off between the higher performance and the life hours, unfortunately. The SilverStar product works harder (not burns hotter, however) to give the whiter, brighter light and that impacts the life hours. The SilverStar product is quoted as "lasting up to a year" (from our FAQ on the website).
The XtraVision is going to provide a wider viewing pattern than the stock halogen providing better peripheral vision, but has the same yellowish tint as the standard halogen. The extra output that is received gives a wider viewing pattern on the road. The XtraVision has a color temperature rating (the way the eye perceives the light) of 3200K."
Bob
