M
Macgyver
Hey does anyone have some good info on Holleys? I recently put on a Holley 4150 and Im needing help on a couple of things. If someone has links to tuning one that would really help.
I cant seem to get the idle right. I tightened the screw all the way and have taken it out and it still idles too high. Im wondering if that means the float level is too high or the power valve is blown.
Also I needed to know what the 2 vacuum valves go to, the high pressure vacuum on the front and the low pressure one on the drivers side rear.
Ive been doing plenty of searches but all that good stuff on carbs seem to be gone from the history.
