7
72-LT1
Hey guys, just a question on the original carb on these cars. I sent the original carb off to Holley for their restoration repair.
The car was stumbling and backfiring through carb and all around running like crap before I sent it off. I put on a 4150 750CFM, mech sec, that I borrowed off a buddy, while they had the carb. The car ran great using this carb no stumbling or anything. The timing and everything is pretty dialed in, and it was running good.
Now I reinstall the original carb (it looks nice), but it really is not running good until it warms up for a while. On initial start up it cranks for what seems a little to long, maybe 10sec, and then it will start and stall when I give it gas. Then on the second start it will run OK, after feathering the accel a few times. It will chug and such on the road until you run it for about 10min.
I was thinking the choke was not working right, it stays open when it cools down, and then closes up when I hit the accel, then it opens up about ¼” when it starts running until it gets warm and opens up all the way.
The fuel bowls are full right up to the holes so I think that’s good and I think the choke is doing its thing, so does anyone have any ides as to why it takes so long to run well?
Thanks in advance
Thanks in advance
