69,
I am running 6 AN fittings and 3/8 fuel line throughout. Looks good, is easier to connect and unconnect than stock hose. I will run hose and hard line from the fuel fitting back. But from it (the picture I posted) to the pump and up the the carb its all braided lines and AN fittings. I had a local hose shop make up the two lines I needed. They were expensive, but should last forever.
Gary,
Yes, true duals with Flowmaster 40's out back. I plan to have new pipe run between the headers and mufflers, probably 2 3/4 inch pipe. I am not running a cross over pipe. I just cant find where to put it.
