blower wire
Thanks to all for the info.
Jim, I followed the link and the post on the blower wire. This sounds like the problem that I have and will start with it. Does the blower work when turned on after taking off the brown wire?
Here is a copy of some replys to this problem from the link.Thanks to all the guys that put these up.
I hope they do not mind me reposting.
To turn blower off instead of lowest speed: Locate under hood, on pass. side at blower resister box, the wire at bottomof 4 wire T nearest pass side, dk. brown on 77. One can disconnect & bend that one connecter down, & reconnect. This is fast & reverseable. Of course
you could remove wire from connecter, esp. if you will be doing this often.I started doing this years ago to save wear on blower motor, less noise w/ blower off & key on.Don't need low anyway!
You don't need to go through the hassle of plugging the heater core. for $10 at AutoZone, buy a generic in line shut off valve (all you need is the hose diameter). Splice into the heater hose running from the water pump. The valve has an on/off lever. Set it to off and stop the flow of water to the heater core. In the winter you can open the valve if you want. Simple solution but it will reduce cabin heat substantially. Worked for me.
While there's nothing wrong with any of the above suggestions, I'd like to make a plug here for originality and GM engineering. Your car has a water shutoff valve already (sometimes called "A/C water shutoff" or "hot water shutoff"). It's located near the bottom of the passenger side firewall, where the heater hose from the water pump goes through the firewall to the heater core. The valve has a vacuum line from the A/C controls that is used to control its open/closed status. Usually due to carbonate sediments in the cooling system, the little flapper valve inside this little jewel sticks open. It can also stick closed, but that's not nearly as common because it's in the closed position much less often. If you like the idea of having your car work as designed, you can get the valve from Zip or other suppliers for about $18. I have seen some of them
that just needed a good cleaning and a shot of WD-40 on the vacuum actuator, and it's always a possibility that the vacuum hose is cracked or has
slipped off the nipple
