S
sagnoff
When I'm driving my new big block over 20 MPH or so, I get a steady flow of hot air under the dash. Lokking, I see an access hole under the dash on the right hand side where the instrament cables pass thru the firewall. The hole is wide open w/o insulation. Have any of you had the same problem? I guess trying to stuff the hole with insulation would be the easy fix.
