Heyblue
1984 I think the last owner put a 160 degree thermostat. Start engine and feel hose from the thermostat housing. Starts to warm as dash reading gets close to 160. At about that temperature (160) it gets quite hot indicating the thermostat opened. Watch gauge and note fan comes on at about 232 degrees and goes back off at about 225, which I think is indicative of a factory original fan switch.
So on a cool morning going into town on a country road at 35 MPH which is mostly down hill the temp gets to about 165 and stabilizes there give or take a few degrees. Side note my 4-3 OD never kicks in. Going home same road going up hill same cool morning temp gets to about 200 and stabilizes. Lastly on warm days the temp regularly gets above 220 while traveling non freeway speeds.
Now the questions:
Is the 200-220 normal while driving?
Shouldn't it be closer to the 160 which the thermostat is?
Is this an indication of the cooling system not doing a good job?
My original thought was to put a 180 thermo with a low temp fan switch (fan on at 200 off at 185) , but that seems would have the fan on all the time. I thought the fan running would only be for idling or stop and go traffic, or low speed driving. The 160 seems too low a temp for good performance, the 232 seems like I would be running close to boil over, especially on a very hot day.
I guess the first thing I need to know is if the cooling system is running fine given the current existing parts.
My 95 truck and 2014 ford fusion both come up to temp (200 in the truck) and stay there. These corvettes seem by design have the temp wandering all over the place.
Now the questions:
