G
GrandSportC3
How can I make my intake seal good on a zero decked block??
On my '68 Vette - I have a zero decked engine that came with a matched intake (matched to the block). I changed intakes..because the one that came with the engine wasn't what I needed... and ever since - I have pretty high oil consumption. Oil gets sucked into the combustion chamber because the intake gasket isn't sealing perfectly... I just replaced the intake gasket again and it didn't fix my problem.. I wonder if there's some kind of sealer that I can put on top of the gasket so that it'll seal better against the intake??? I don't want to spend $1000's to have the engine pulled and the intake matched to the block...
Any suggestions??
Any suggestions??
