Tom,
generaly speaking, there are several things that stay true with head designs
: the bigger the intake port, the higher the operating rpm for the head. small port = low rpm and good torque, big port = high rpm and poor idle do to less signal to the carb.
: chamber design dictates compression ratio and burn pattern for maximizing the eff. of the motor.
: straight plug vs. angle plug, angle places the spark closer to the intake valve and improves the burn pattern and scavenging.
: inake and exhaust port design adjust flow chacteristics for different set-ups, ie. cam profiles.
: polished ports flow higher numbers. intakes can be mirror polished if you are running a very good carb, Barry Grant or other racing type carb, that has very good atomizing characteristics or EFI.
then you get into very technical stuff about making small amounts of power. most head manufacturers won't disclose more info than what is listed above. Lingenfelter's book and other engine building books are very good sources of information about heads. heads are the most important part of the engine for maqking power. to put it in perspective, my brother-in-law's nephew just graduated from a performance engine building school in Houston, Texas. the school puts engines together and the graduates are snapped up by NASCAR and USAC teams. the course was 18 months and ten months were spent on heads alone!!! this school built a street legal Camaro with operating AC, stereo and power windows, it runs the 1/4 in the tens with a small block!! Brian
