Vref
How do I fix this fiberglass crack? Its on the inside front drivers side wheel well on a 65
IH2LOSE said:Look like a i piece front end. It may actually be a crack,
Show us a picture from the engine side
stepinwolf said:Vref, It's not a crack in the fiberglass. What you are seeing is a separation between the top of the fender, and the inner fender. These two panels are normally solidly bonder together, but incorrect previous repairs, or major stress between the two panels, can cause this type of separation.
The best way to repair this type of damage, is to carefully pry the two panels apart, and using the correct bonding adhesive, squeeze as much of the product as you can, into the opening, and then remove whatever tools you used to separate them and let the adhesive set up properly.
I don't know of any tools that can be used to help in pulling them together before the adhesive hardens, other then drilling a few holes , and using screws to pull them closer together. The screws can later be removed, and the holes filled.
Stepinwolf
