A
aoriii
I've seen a lot of discussion regarding how hot our C4's tend to run, but I've not seen any posts regarding what temp they should run at. I've been battling high temps and the Alabama summer months, and have developed my own little psychosis about heat (I'll call him Fred). Anyway; I've just finished my own work around solution as suggested by friend who once owned a C4. I've wired the front cooling fan to an ignition hot wire under the hood, so now whenever the key is in the ON position, the fan is running, this takes the computer out of the equation of deciding when to come on (I'll likely do the fan behind the radiator the same way).
So, back to my original question? Where should our temps be? Before I did the re-wiring, my car would run between 195 an 220 while I was moving, but when I stopped the temp would rise RAPIDLY . I've seen it get as high as 235 sitting in a parking log with the A/C running. Since my re-wiring, it runs between 190 and 203 when the car is in motion (it'll get down to 190 when I'm on the highway @ 60+). When I stop the car it will not get to about 220 if it sits for awhile....
So again, how hot is too hot, what should the normal operating ranges be???????
Trey - steamin' in bama.
