norvalwilhelm
With the roll cage I wanted 5 points for both the driver and the passenger.
This is how I did mine.
My 75 had metal inserts in the seat at the shoulder height. They look like all they need is cutting the slot from the factory for shoulder seat belts. I removed these inserts and milled a 3 inch slot in each side. While it looks like the slot runs crocked it is straight, it is the shape of the insert that makes it look crooked.
I also remove the covering and the foam from the frame and cut out the slots in the frame by drilling a hole in either end and using a grinder and cutting blade.
I also cut the seat cover. I did a poor job of it here and will take it to an upholstery shop for leather to be sewn around the edge to reinforce it.
While I am at it I also like to narrow the seat, I change the width from 19 ½ to 18 ½ by cutting and straightening the hinge. The stock hinge is curved to clear the sides of the seat by a lot, I want it 1 inch narrower so I do this modification. I want it narrower to give more seat to center counsel clearance and more clearance on the door side for the roll cage bar that runs low just above the sill from the trailing arm pocket to the front down tube and through the firewall
This is the finished drivers seat with the 3 inch belts passing through the back of the seats.
I don’t actually run a 5 point, I run 4 points, the boys vetoed the 5th belt.
