Stallion. As mentioned above, the motor mounts, under normal condintions will not be a problem. However, older cars and cars with major modifications done to the engine will stress the motor mount to the point of failure. Some fail-safe measures I have seen on high HP engines is to mount a chain from an exhaust bolt (or similar location bolt) to the frame rail that the engine mount is attached. This is done on the torque side only of the engine and it will allow the engine mount to work to it's maximum before the chain tightens. There are hardened motor mounts available in the after market sector that are more reliable and not so (Goddy) looking as the chain.
