How is the handeling on the C6 Z06 in dry weather?
mdj89
Texas
How is the handeling on the C6 Z06 in dry weather meaning, making sharp turns or corners, and top speed? We had a 1999 mustang gt, that would loose controle real easy if made a certain turn.
The C6 Z06 is one of the best handling Corvettes ever built. I'd hazard a guess that if you wanted a better handling Corvette, you'd have to buy an '09 ZR1. Check out the press releases and performance reviews of the Z06 in our 2006 Z06 Model Center
:thumb Jason
I would agree that the handling of the C6 Z06, in dry weather, is exceptional.
Driver ability is the only drawback.
A good driving school like Spring Mountain, Bondaurant, or Skip Barber, should be on everyones "to-do" list if they want to do any spirited driving.
Bob
The handling is just what you'd expect from a lightweight car with wide tires. Not bad but could be improved on by having tires with a higher coefficient of friction. It never ends...:W
Dry weather handling is excellent. One of the best Corvettes I've owned. :thumb
Here in Michigan, we get that 40 degree weather, and that's when it becomes challenging! :thumb
