jimmyb said:
Ken,
The number I saw for 2006 ZO6 was 15% - 20% (5250 - 7000 cars) of total Corvette production of 35,000 cars. The engine plant can produce 15,000 units per year. I couldn't find Rob's post on year end 2004 numbers which breaks down ZO6, coupe, and convertible numbers. I'm curious about the 2004 ZO6 number.
Jimmy
jimmy - no flames here, but, i'm just curious about the 15000 engines number. where did you get that info? according to the video that's floating around, one of the gm guys (at the engine plant) states that they can produce 15 engines per day. again, 15/day x 5 days/week x 50 weeks is 3750 units. the video also states that the assembly guys are the "cream of the crop" engine builders. each engine is assemblied by a single worker in one day, and a nameplate is attached to the engine with the builders name. now 15000 engines would be 2 to 3 times the number of 06z06 engines required based on a 15-20% production number. either way, 3750 or 15000 engines, the numbers just don't add up to a 15-20% level. based on '04 numbers, about 20% of total production was z06's. if the same holds true for the 06z06, then gm is going to need about 6500 engines. i really think the 06 production of z06's will be closer to 10%, and ramping up in '07, '08, etc., to the 20% level. bean counters will be doing a market study on this one. if the 06z06 price goes through the roof, demand may not be as high as anticipated, i.e. 20%. several of my z06 buddies are saying, anything above 65K and they are out.
Joe C - 2004 black/mod red z06, 1985 silver/graphite z51 (both daily drivers)
correction - i just watched the video again, the gm team leader states that there are 15 workers building engines,
and each line can produce 15 engines per day. so this just brings up the question of just how many engines can be built per day? how long does it take for a person to build an engine, and how many can that person build in a day, and how many production lines? i would think it would take the better part an 8 hour shift to build an engine, assuming one has all the parts on hand all the tools (conventional and specialized), but i could be wrong. if a person can assemble an engine in 4 hours, then that would be 2 per day x 5 days x 50 weeks or 7500 engines per year. that number sounds about right.
