E
ElectroCulture
I just bought a 1997 C5 with 86,000 miles. I'm just wondering at what point does reliability come into question and I'll start to think about a new engine.
~C
~C
If you change oil like you are supposed to...the engine will last a very long time...ElectroCulture said:I just bought a 1997 C5 with 86,000 miles. I'm just wondering at what point does reliability come into question and I'll start to think about a new engine.
~C
The L98s in the early C4s had some engines documented at over 400,000 miles. With the six speed transmissions and resulting lower rpms at speed, the advance in materials, and the use of synthetic oils, the C5 engines with proper maintenance as outlined in the above posts should certainly reach those figures with ease. At 86,000 miles it should just about be broken in good. Have a nice ride.ElectroCulture said:I just bought a 1997 C5 with 86,000 miles. I'm just wondering at what point does reliability come into question and I'll start to think about a new engine.
~C
What article is this? I'd like to seevettenuts said:Just to add to the mix, the LS-1 is a well designed motor that can handle high loads for extended periods of time. A friend recently showed me an article where it is finding its way into home build aircraft because of this capability and its durability. Since an airplane motor is always working hard, I suspect that in a light Corvette it will last a very long time![]()
Echoing the other responses, if you do the maintanence, the engine should last a very long time.ElectroCulture said:I just bought a 1997 C5 with 86,000 miles. I'm just wondering at what point does reliability come into question and I'll start to think about a new engine.
~C
