Remo: as vettepilot said, the primary benefit of nitrous is the added oxygen (nitrous oxide is 36% oxygen, by weight - regular air is only 21% oxygen, by weight). The cooling factor does add in, though, by making the air more dense (as temperature goes down, the oxygen
eight ratio remains the same, but the oxygen
olume ratio increases). More oxygen means more power. Well, as long as you add extra fuel to go with it, that is... more oxygen
without more fuel = boom!
Stallion: yup, that's the idea, except forced cooling would get the air even colder than the outside air.
The main problem does seem to be packaging. I know it's been done with drag cars, using a cooler full of ice as the cold sink. A continuous heat pump from something like an A/C compressor would be necessary, for a regular street-driven car.
I gotta think about this one, from a packaging, weight, and complexity standpoint. If it could work, it would be a very cool mod. (no pun intended)
Joe
