firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
The 3rd member supplier told me to add it up to the fill hole level.....well, there is only one hole on the differential and it looks more like a drain hole than a fill hole.....it is on the bottom of the housing.....so do I just poor the 3 quarts of lube plus the 4 ozs of posi lube into the housing and put the 3rd member in and button it up????????
thoughts?
notice in the photo below that there is no fill opening up high.....there is a drain plug in the very bottom....
notice plug on the very bottom
this is a Ford 9" rear.....
thoughts?
