How to lock in Targa top (front)
cals1993
Merrick N.Y.
1993 teal coupe
Recently purchased a 1993 vette with glass top tried putting it on last night went for a drive and the thing was bouncing all over the front was not locked down. How do you lock the front i don't see any levers or anything. Help
How did you "lock it" down in the back? There should be two torx head screws in the back that go in horizontally, and two in the front that go up from the bottom on the vertical axis.
It bolts on to both forward corners. There should be a small ratchet with the car with a socket that fits the screw head, may be a Torq screw, can't remember that far back. ;shrug
They are up under the sun visors and helps keep the flexible flyer from shaking too much by the top becoming part of the body structure.
Save the wave......:w
Just found 2 screws put them in the back nothing in the front are they the same size screws didn't notice any wholes in the front but it was last night and it was dark. Do you think I can get them at pep boys, anybody know the size?
The bolts should be trapped in the windshield header, look up the hole with a flashlight. They are the same head size as the rear bolts.
