norvalwilhelm
I believe in electric pumps but not their reliability. I always run 2 with seperate switches and like a plane check each pump by itself when running.
Anyway electric pumps can be noisy so I got these dampeners. They are used but can be bought from any bolt supply house. They have a variety of dampeners. YOu just need one with the right bolt pattern
These are two flanges joined to gether with an inch of rubber.
I put a bolt through the center of one flange and bolt it to the frame. I bolt the pump to the other flange.
I do not hear my pump when the motor is running and only a slight buzz when priming before starting
These are old
These are old
