How to replace LT1 injector link
  • Thread starter Thread starter switch
I had not heard about that switch. What do you hope to gain?
Has someone else already done what you are doing? Your instructions were clear and accurate.
These LS1 injectors aren't much different only 25.5 lbs, but since they were designed to operate at higher fuel pressures, This will allow me to raise the fuel pressure when I start run out of pulsewidth. The stock Multecs sometimes don't like too much of a pressure increase.
Gordon
WitchHunter Performance
http://www.witchhunter.com
Gordon,
Excellent job on those instructions. If I ever need to get at the injectors, I'll certainly use this as a guide. Now if only the GM Service Manual explained things in the detail that you did AND included "real" color pictures instead of drawings.
By the way, that's the cleanest-looking LT1 engine that I have ever seen.
Jack
