firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
We worked on Saturday setting the wheel base length on both sides as well as the angles for the driveshaft.
First the driveshaft, when we first measured the end of the transmission and then the pinion gear drive yoke we were off about 3 degrees or so from one another. Because we don't want drive shaft wind up, caused by non-equal angles at both end we needed to get them as close to dead nuts as we could.
After we adjusted the 4 bar links a couple of times turning the end link a total of 3.5 turns on both sides, this is what we were rewarded with in angle measurement.
Below is the end of the transmission side
Below is the pinion gear drive yoke side
Next we had to check/set the distance on both sides to be equal from the front suspension to the rear suspension. We measured from the front lower ball joint bolt front side to a cast spot on each of the rear disc brake back plates. We were off on one side by about 3/16-1/4" to the other side. so we extended out one side to bring them both into the same dead nuts measurement.
Below is where we measured at the ball joint on both sides.
Drivers side rear disc brake back plate
Passenger side rear disc brake back plate
Next we needed to set the camber, but that we were not sure how to do. So if anyone has some good instructions or procedures to do that with this kind of set up below, that would be really helpful.
Camber setting procedures?
thanks, Herb
thanks, Herb
