L
LT1Vettepilot
Its time for tires up front, and one of my wheels has a small crack in the bead area which is causing a slow leak. So I'm looking at grabbing a set of 17X9.5 "A" mold wheels for all 4 corners. Going wider up front will allow me to toss the "narrow" 255/45s. I was going to get 275/40s for the front, which I know fit just fine since it was standard on the ZO7 handling package, however I've discovered that the 285/40s (rear tire size) is on sale for almost $100 less per tire. Question being, I know they will fit the wheel without a problem, but will I have rubbing problems up front when I turn? I threw a rear wheel up on the front the other day while I had it apart for other reasons, and the 285 doesn't stick out beyond the wheel well, so there shouldn't be any problems. Since I had the car on a jack, I didn't play around with the wheel to check clearances. Anyone tried 285s up front yet? Thanks
