HVAC codes and intermittent blower speeds
Jonboyauto
New member
West Coast
Vehicle has a consistent B0446 and intermittently flashes B0361, B0363, B0365, B0367 with snap on scan tool viewing live codes. History codes show listed as well as B0441. Blower resistor module was replaced due prior diagnosis. Blower now operates either on low or high speed intermittently, no specific sequence will activate/change speed. Does not adjust with control head. Temperature blend air doors also operate sporadically...slow to respond to control head when they seem to work. Have not removed either motor for inspection. Thank you for taking the time to read and respond.
So, you have a Manual system and not Dual Control, correct?
Dual auto climate control system. Found output broken gear in drivers side actuator and pass side seems bad as well...hard to access without some dissection. The next issue is figuring out if the blower motor speed/function will improve after replacing the blend air door actuators. Blower will blow full speed on auto or very slow sporadically.
