Roadster Guy
- Joined
- Oct 17, 2004
- Messages
- 261
- Location
- Rolling Hills NE of Toronto
- Corvette
- 1996 Roadster CE/LT4/F45
Since I've owned my Vette (7 years now) I've always accepted the fact that when I set the climate control to auto cool, say at 68F, I can feel the compressor (or AC system) cut in and out as I drive. By that I mean I can feel it drag on the engine or performance as it cuts in and then more power returns when it cuts out. It is a bit subtle, but there none the less. It is more noticeable at low speed. None of my other cars has this happen where I can feel what I assume is the compressor cutting in and out.
The climate control works great and cools well in any heat and even when crawling around the city it maintains the set temperature. The engine runs at the proper temp in all temperatures and driving conditions. The engine starts and runs beautifully. Because of this I've always just figured the AC drag was ok.
Is something not right here or does this happen in other Vettes with Climate Control as the system tries to maintain the temp?
RG
RG
