I can probably guess the answer...
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
But let me ask y'all anyway. :CAC
According to the Helms service manual, the ABS has:
A fuse located in the main fuse panel, labeled BRAKE, provides protection for the main power feed circuit of the ABS electrical system.
However, there is a caveat...
NOTE: The GAUGE fuse is also tied into the main power feed to the ABS.
Now, when I use my roll control for holding the car while doing tire warmups ;) and I pull the fuse to prevent the ABS from kicking in, will I lose my electrical gauges as well? I'm not concerned with the oil pressure, oil temperature, or coolant temperature because they're mechanical, but I do still have a few electrical gauges such as fuel pressure and level, as well as voltage of course.
Reason for concern, or just worryin' needlessly? ;shrug
attachment.php
Let me se if I can help.
I have a roll control as well, it is connected right off the mastercylinder and then sent to the front brakes.
When I set my line lock and then heat the tires, the ABS does not kick on because your foot is no longer depressing thr brake. I have had no problems and I don't pull any fuses
-=Jeff=- said:
... the ABS does not kick on because your foot is no longer depressing thr brake.
Hmmm... Makes sense.
