I FOUND Z06 GRAY WHEEL TOUCH PAINT!!
  • Thread starter Thread starter Dr C5 Corvette
D
Dr C5 Corvette
Hi Everyone just found a great match for $5 at my local Pep Boys store its really close and looks great here is the Duplicolor #NG- GM435 LIGHT GRAY MET. I Used my Dremel with an light abrasive wheel on the very outer lip and smoothed out the nicks as best as possible then cleaned with denatured alcohol then applied the paint with the brush that came with the bottle. It looks great and has a gloss finish to boot gave it 2 coats I am very happy :D with the results hope this helps others ...............Dr C5 Corvette
Thanks for the info, I have a couple of nicks that need touching up on my Z06 wheels as well..:upthumbs
Hey Bobby, No Problem Glad I found it. Make sure you shake the bottle well before applying. Bobby I am a Big Advocate of Amsoil Products, I run 10w 40w motorcycle oil in my bike. How do you like it in your Z06 compaired to
Mobil 1, did you notice any difference in temps,performance or cold start noise thanks Dr C5 Corvette
