A
AngelSixx
Hi all,
I just bought an 85 vette and decided to do a tuneup on it. New cap, rotor, plugs wires etc. started it up ran fine.. Decided to set the timing and after much hard work and frustration, i managed to loosen the distributor bolt. I unplugged wire to put it in bypass mode and turned the distibutor so that the timing was set at 6 deg BTC. then tightened the distributor bolt back down and reconnected the wire. I started the car up and it was running very badly, checked the timing with wire connected and the mark is jumping all over the place. Lots of smoke comes out of the exhaust and it smells really strong like gasoline. Fumes were so bad it makes my eyes burn. Idle jumps all around and just plain runs badly. Afraid to drive it to the shope even. Any chance anyone out there might have any ideas?
P.S. this was the first time I have ever done a tuneup and i'm also a fist time vette owner. Any help would be greatly appreciated.:confused
