grumpyvette
I need some battery info, guys
all three of my corvettes get driven sporatically,they tend to sit in the garage occasionally ,while I drive the others , sometimes for up to three weeks at a time, now its can be because Im doing engine or drivetrain mods, engine swaps, ETC. which I do frequently or just don,t feel like driving that particular corvette, but the end result is that the batterys in the vettes tend to go dead,faster than if they were in use daily even if I use a charger on them, fairly frequently.I usually have batteries die after about 15-20 months, even those garaunteed for 72 months, and its a P.I.T.A. dealing with warranty B.S.
example WALL MARTS best battery tends to go about 15-18 months even thou its warranteed for longer , and the reciepts tend to get lost or fade so you can,t read them.
QUESTION, has anyone found a type or brand of battery that goes long term better than the standard car batteries, IM thinking a marine deep cycle battery may be the trick here???
"Why not hook up a battery maintainer?"
I have several chargers, and use them constantly,on trickle charge,the batterys just don,t hold up as long as I think they should, unless I drive the car frequently, personally I think the vibration durring use helps keep the battery plates cleaner
opinions.info welcome guys
