D
Da Hawaiian Punch
[font=Verdana, Arial]I'm installing a hot cam 525 lift in a couple of weeks into my '91 L-98, I have the free mods like everybody else along with the 1.6 roller rockers, ported intake samese runners and ported plenum like you have have already, march underdrive pulleys, straight pipes out back (no mufflers or cat's), MSD 6-A ignition box, cold air induction with K&N air filter and I have 3.07 gearing.
This is the info on the cam I'm installing:
This hydraulic roller cam "LT-1 Hot cam"
The duration at lash point in degrees (intake/exhaust) is 279/287; duration at .050" tappet lift (intake/exhaust) is 218/228; and maximum lift with with 1.6 rocker ratio (intake/exhaust) is 525/525. Valve lash is zero/zero and lobe centerline is 112 degrees.
My question is will i be able to drive decently without any extra things done to my chip (that was burnt by T.P.I.S. for the mods that I mentioned that I did) untill I can get a hold on a scanner to scan then have somebody burn one for me?
in other words, will I be fine driving untill I can get a chip burned for the cam shaft mod?
Much Mahalo's to all you folks for taking time to read and answering me this question gang!!
Aloha Nui loa (Thank you very much)
Kalani.[/font]
Kalani.[/font]
