Ididit steering column wiring question
cbernhardt
Lexington, NC
62 Conversion Car, Pewter 98, 59 Project
Started wiring the '59 today and cannot find the wiring diagram for the Ididit steering column, the one they make for C1's. Does anyone have a wiring diagram for this column that they might email to me? Or just the connection descriptions for the wires which are colored white, green, yellow, purple, brown, dark blue, light blue, and black.
Thanks,
Charles
John Mcgraw
Austin Tx
1960 Roman red, 1959 resto-rod, 1965 resto-rod
Charles,
Here is the color code.
Terminal P is the brake light feed and it should be a white or black with white stripe wire.
Terminal N is the right rear turn signal and should be green.
Terminal M is the left rear turn signal and should beyellow or black with yellow stripe.
Terminal L is the turn signal feed and should be purple.
Terminal K is the 4 way flasher feed and should be brown.
Terminal J is the right front turn signal and should be royal blue.
Terminal H is the left front turn signal and should be lt blue or black with lt blue stripe.
Terminal G goes to the horn relay and is black.
Regards, John McGraw
IH2LOSE
We Will All Meet Again
1966,and a 1962 thats almost complete
Charles do you need more ?
As always I am late with ideas but I am going to add the rostra cruise control to the car. so if your column is still out I would suggest running 4 16 ga wires thru the colomn now incase you decide at a later date (as I did ) to add cruise control.
Trois Rivieres, Quebec, Canada
63 Resto Coupe-Red 65 Roadster
This time I didn't screw up
Good idea about the cruise control. When I purchased my column from " Flaming River " , I purchased the turn signal/cruise knob from " Ron Francis Wiring " and sent it to " Flaming " so that they could set it up, and run all the wiring through the column before getting it out to me.
Stepinwolf
cbernhardt
Lexington, NC
John:
Thanks for the information. After looking everywhere in the shop yesterday I found my instruction sheet this morning hidden away in my receipts folder in my office.
Charles
IH2LOSE
Thanks,
Charles
Charles
are you doing an entire new wiring harness? or just blending old with new?
cbernhardt
Lexington, NC
Larry:
I'm using all new wiring. The harness I'm using is by "E-Z Wiring". The fuse block is really small (about 4" x 2") and the flashers are separate so you can mount them just about anywhere under the dash.
Charles
IH2LOSE
Charles I am sure you have done it before but the best word of advice I can give on installing a new harness is to use the small wire tires to lay it out and st it where you want it.after you know psitively for sure all of your wires are where you need them ,then cut off the ties and wrap the harness with tape.
I cant tell you how many times i had to cut the tape off of my harnesss after I thought I had it completely done. At carlile i still had the ties holding the harness because i just unwrapped the day I was leaving for carlile to get the leads for the power windows
Islander
Florida
1966 roadster
Stepinwolf,
Which model cruise control lever and system did you get from Ron Francis? I'm also using a Flaming River set up for my 66/LS2 roadster project and may want to add cruise from the get-go.
Cheers,
Islander
Islander said:
Stepinwolf,
Cheers,
Islander
I was told that the only unit that would be correct for my application with this column was the model CC-25. In their catalog it retails for 38$.
Stepinwolf
Islander
Florida
1966 roadster
Darn, that was quick, thanks! Did you use a Francis electronic unit or did you go with a Rostra or something else?
If I was not quick, how in h*ll could I build two midyear projects at the same time.:W
I was planning on going with the unit from Ron Francis, unless someone offers me something better. However since I have not as yet purchased I'm open to any suggestions
Stepinwolf
vetteman64
california
1959 & 2000 Corvette
I too am working on a 59 Corvette hybrid and would like to have more info on this "rostra" cruise control. I need something that would work with a T-56 trans and modern electronic fuel injection on an early small block (1973 350). I bought my T-56 3 years ago, and it has electronic speedo, planned to use an "X-box" which looks like it will also "drive" a Lokar cruise control. Keisler rep stated he would swap my T-56 for a current mech drive speedo model, but I still want to add cruise control. (I am using rebuilt factory guages, did not want to cut the dash for modern guages).
Joseph Rock
Frankenstein 59
IH2LOSE
Joseph Rock
Frankenstein 59
Ididit uses a rostra set up. I am not sure what they are using for the switch set up
This is rostras website http://www.rostra.com/ParkPilotParkingAide.htm
as far as I know lokar is just making cable kits to work with the rostra cruise control unit.
When you get a chance bring us upto speed what your plans are with your 59 as we all are interested
1964charles
New member
texas
59 vette wiring
Thanks,
Charles
Hi, I'm Charles also, and am restoring a 59 vette, and need the wiring colors from the wiring harness to the steering identified. I have the ididit side identified. thanks for any help.
