Cruzer82,
I hear what youre saying and i used to think that Car Manufacturers were on top of everything that they built ; but...take for instance your radiator and a/c condensor --- if you look at virtually ANY car, y oull find a huge air space on the sides (and sometimes top and bottom) , where alot of air is being bypassed around . Wouldnt you think that thier R an D could design it tighter so the radiator and condensor would receive better cooling ?? On every car i buy , i seal up those huge gaps.
Ive been told , that, in actual operation...the oil filter bypass is bypassing oil not only on startup when the oil is cold...but continues to cycle even after the motor is warm. I read recently that, GM uses only a 4 psi differential setting for the bypass valve - this means youre in bypass mode much of the time.
I do , in fact, change my oil with filter every 2500 miles and use synthetic . But i want to offer my newly rebuilt motor maximum protection from dirt, etc... To get around any chance of a plugged oil filter... i shall keep an eye on the pressure guage and will have a backup oil pressure switch to shut off the engine .
Dave
