E
ernie d
I am replacing my standard (non tilt/tele) steering column with a rebuilt tilt/tele column. Have noticed that the ignition switch and vehicle harness connector is different between the two. :eyerole
The vehicle harness will only connect to my old (non tilt) ignition switch. I assume if I simply swap the switches from the old column to the new that things will not work correctly.
otfl
What do you suggest???
Thanks!
Thanks!
