L88 crazy
I have engine misses when Iaccelerate. It's ignition for sure because the misses have a burpy poppy sound to them. I just installed a new rotor yesterday as well as a fresh tune up on the carb. I have triple checked to make sure I properly tuned the car up and I did. The Vette runs AS PERFECT AS EFI! The vacuum hoses are all properly hooked up and working. I have a Unilite breakless distributor with tach drive as well as Accel 8mm ignition wires. I am using to what appears to be the stock ignition coil. Is the coil causing my problem?
