93Rubie
For better or for worse, I ran my first ever event in mid August, I just did my 4th one last Saturday. It is a ton of fun, and I am learning a LOT, both about the car and me. Kinda of funny but the more I use my Corvette in motorsports and drive it too, the more I really love this car. It proves itself over and over again as being one of the best sports cars in the world. If not THE best. FYI, I think I held my own in B-stock against folks with MUCH more experience in their S2000's and Boxsters. We all where in the tire class=street tires so that evened things up a bit. The course was fast and open. Something my first 3 times at auto-x the courses where extremely tight by comparison. My best was 43.8. The others best in the low 40.XXX bracket. I did beat a fellow rookie in his 08-present Subaru WRX STI. Nice to see a 18 year old sports car kicking new machinery to the curb. I can tell looking back where I lost speed and what I did wrong. The car has SO much more speed in it. Needs a better driver...:eyerole Less hamfisted inputs and throttle applications...:ugh and more smooth. I was lower mid-pack with my PAX times. Closer to mid-pack than the bottom.
To get to the point of my post, I have been studying the SCCA rule book for Stock classes, C4's are in B-Stock. It allows some room for mods but very little. I intend to stick to B-Stock because...A: It will take quite a while before I get to where I can outperform the car. Even a C4 has very high limits and performance potential. B: It is cheaper... C: Since I drive, show, race, etc...this car closer to stock the easier to maintain and live with.
That being said, my 93 has the FX3 suspension, I can run the Z07 setup as it was an option on my car. Since mine does not have Z07 I will have to piece it together. From the 92-95 Z07 setup which was the same all those years according to our C4 Suspension Chart. I already have the rear 24mm sway bar and the FX3 setup. I need the the below:
1. Front 92-95 Z07 spring 90.1 (n/mm) FSK spring code
2. Rear 85-95 Z51, Z07, R9G spring 57.2 (n/mm) NYU spring code
3. 30mm Front Sway Bar 85-95 Z51,Z07,R9G
4. HD Lower Control Arm Bushings
I think that is all. The rear spring NYU and the 30mm bar should be easy to find. The front spring and lower bushing, a bit harder.
Would the 88-91 Base front spring at FHA 93.1 (n/mm) be an acceptable alternative to the Z07's FSK, they are very similar.
Also, other than finding low mileage good condition lower control arms from a 92-95 Z07 car, is there an aftermarket alternative or even maybe the lower control arms from a Z51 88-91, 96 car?
I'm not sure on the early 85-87 Z51 30mm front bar fitting on the later suspension? I don't think they would. I know the rear spring should be compatible from 84-96, fit wise.
Also, since I have the FX3, lets say I get a Z07 setup under my car, would it be worth while to add stiffer Moroca valving to the Bilstien shocks? Also, would a FX3 Motor sports Controller be a good idea, or would these parts or a combination thereof, make the otherwise good Z07 setup too stiff for good handling. Lets face it, too stiff and instead of absorbing bumps mid-corner in a parking lot, you go skittering off because the suspension cannot absorb the hits and bonces too much.
