Stallion said:
I was wondering, what would happen if you, say, increased the L48s compression ration from 8.2:1 to, say, 9.5:1? Would you get a noticeable power increase (hp? tq? both?)?
Both. On the downside, if you push the compression too high, you can end up with detonation. 9.5:1 would probably require 93 octane to run comfortably. Running only 9:1, I can operate on 87 octane.
Stallion said:
And how would you go about to increase the CR?
You reduce the closed chamber volume. This is determined by the stroke, cylinder bore, head gasket bore, head gasket thickness, piston volume, deck height, and chamber volume.
Let's say you don't want to rebuild your engine right now, so you want to keep the same pistons, stroke, deck height, and cylinder bore. That leaves you with two areas you can work on: heads, and head gaskets.
I'm not sure what the actual numbers for the L48, so let me invent an engine with a 8.2:1 CR, and we'll make some changes. My invented engine has the same 4" bore and 3.5" stroke as your engine. We're going to set a deck height (the distance that the pistons are below the top of the block, when at top-dead-center) of 0.050", a piston volume (the piston is not flat - it has clearance dents for the valves, and they have this much volume) of 9.5 cubic centimeters, a combustion chamber volume of 72 cubic centimeters, and a head gasket thickness of 0.040"
That results in a 8.2:1 CR. In other words, the volume of air that can be placed in there when the piston is all the way down, is 8.2 times the volume of air that can be placed in there when the piston is all the way up. So, since the valve closes, and keeps the "down" air in there, the air is squeezed (compressed) to a smaller size.
If we pull the heads off this engine, we can do several things to increase the CR. We can simply put in a new, thinner gasket, and put the heads back on. Let's replace that stock 0.040" gasket with a 0.020" gasket. Run the numbers, and the CR is now 8.51:1. Drop to 0.010", and the CR jumps to 8.67:1. So, that's one option.
The other option is to change the chamber volume. The chamber is part of the head, so you can do this by modifying the heads, or replacing them entirely. Let's say we put back that 0.040" gasket, and take the heads to a machine shop, and mill off some of the metal (essentially moving the head lower by a small amount). Let's say we mill off just enough to drop the chamber volume from 72cc to 70cc. The CR will go up to 8.35:1. Or, if you decide to use the 0.010" gasket in combination with the modified heads, the CR will go up to 8.84:1.
The other option is to put on new heads. Let's say you pick up a set of 64cc heads, and put back the 0.040" gasket. You'll have a CR of 8.83:1. Go with the 0.010" gasket, and you'll have a CR of 9.39:1.
Of course, all this is for the imaginary motor that I thought up. I'm not sure what the actual piston volume, chamber volume, and deck height are for a stock L48, so there's no way of knowing exactly how much each change would affect things.
Stallion said:
What's the science behind it? Just able to get more air into the engine? Or is it more than that?
The idea is to take the same amount of air (roughly related to the displacement) and squeeze it into a smaller space. This improves combustion (the closer all the air can be to the spark plug, the better, since it will take less time for the flame front to move outward from the spark to the last it of unburnt fuel) and high-rpm power (in order to fill the cylinder, the cam must remain open for a certain amount of time, but the actual opening duration decreases as the rpm goes up - higher CR allows the use of a longer-duration cam, which will stay open longer at any given rpm).
Those are the basics, anyway.
Joe
