Ing Ploblems
EYESOFTEX
Fort Worth, Texas
1972 Corvette (C3) LT1
1972 Stock Electronic Ign. probloms
72 Stock Electronic Ign problems first time my Ign. went out it got down to 20 degrees,problem must be old parts,changed Module.Well it got down to 20 again and i am getting no spark again ,got power to the disbutor ,but no spark, could it be the condenser?. or just a bad new module again.help!!!!!!!! Rex
What type of ignition do you have?
Mike
Ign problems
Its Factory Electronic Ign H.E.I. . When it got Cold the last time i changed the Module same day and it started right up , now its gone out again same kind of cold . and i don`t know what to do but put another module in it , But will it go out again? Help !!!!!!!!!!!
Is the coil in the cap or mounted seperate?
Ok, what gauge wire is connected to + terminal in cap and what brand modules are you using?
I`ve been a mechanic all my life , but Electronic ign . are not my strong point. i`ve had problem in the past with old points and condensers,and had problems with to much power to the dist.and a bad coil ,but this drives me nuts. it`s stock wiring harness,never been rewired ,same old ign switch . so i`m thinking new cap new coil, new module , but what i sam thinkig is what about the ting that looks like a condener sould i replace that too ?
