H
handstjg
Anyone have an article on removing and replacing the injectors on an 86 L98?
Do you know if there is a check valve in the fuel system? The fuel pressure is 37 lbs. at idle which is within specifications. When you turn on the key it jumps up to 30 lbs. before I start cranking.
The Car Whisperer said:I replaced them with a new flow balanced set. I think you're doing the right thing to replace every o-ring and seal while you have it apart. It's not just the milage, but the age of the car that I considered when I changed my injectors. Are you doing it yourself?
