Help! injectors
Yes, go to your local parts place and rent a noid tester, they connect to your injector connector and light up when the injector is fired.
Check your ECM 1st to make sure it is connected correctly and what is you fuel pressure?
You can also hook up a volt meter to a connector and have someone turn the car over and you can watch for voltage, but this is not a good way to check.
