Install of CD-Changer in C-4
  • Thread starter Thread starter mygr888
M
mygr888
Hi!
Just have a quick question regarding the install of a CD changer to the stock radio in a C-4. This changer hooks up to the antenna. Do I find the juncture behind the radio or closer to the antenna in the rear?
All help appreciated!
-M
If your 88 is like my 90 and pretty sure it is... look passenger side under dash near the fuse box . It plugs into the what i believe is the cdx amp box. Pretty tight fit . good luck
nyernga said:
If you're talking about one of those RF signal changers then the antenna connection is accessible by removing the radio. You can "tap" into the cig lighter for the constant hot lead and then the fusebox for a switched power source.
Len:w
Yes it is one of those RF models. Thanks. Any suggestions for an appropriate place to set the unit?
There is another connector at the drivers back corner of the car. Just a few inches past where the cord enters the car next to the antena. Both should work, but the connection under the dash may be closer to the other wires you will need to hook up.
