C4CRAZY787
It’s a Hayden #514, 3/4”x 7.5”x 12” tube and fin design.
I placed the cooler on the AC condenser up in front of the primary fan, 3 weeks ago.
Pic,
http://forums.corvetteforum.com/photopost/data/1064/36404transcooler5.JPG
Then ran the hoses out the right side of the upper radiator shroud thinking the return line was the top one, NOT… it’s the bottom, not having the time to hook it up I just left it.
So after 3 weeks of thinking about it I finally engineered the plumbing. Used a 20” stick of pre-flared and fitted 5/16th tubing, ran it up from the lower radiator cooler outlet and connected it to the cooler hose.
Purchased a tubing bender for the job (always looking to new buy tools). Took some time and used coat hanger wire to get the bends just right.
Pic,
http://www.digitalcorvettes.com/photopost/data/652/997cooler_lines_3.JPG
Luckily, I was able to bend the transmission return tube up and attach the hose from the cooler. The main objective was to not have the tubing and hose rub on anything, but where it did I installed some black plastic wire loom.
Pic,
http://www.digitalcorvettes.com/photopost/data/652/997cooler_lines_2.JPG
http://www.digitalcorvettes.com/photopost/data/652/997cooler_line_1.JPG
This job was a little more work than I had anticipated but it’s finished and looks good.
Pic,
Pic,
Pic,
