I'm sorry, maybe I did not clarify. On the bottom a-arm the shock in your picture bolts to the bottom side of the a-arm not to the top of the lower a-arm. Looking at my VBP a-arms the nut (tabs) are welded to the bottom of the a-arm (opposed to the factory which are welded to the top of the a-arm). So bolting them to the top you're using the strength of the plate of the a-arm as the factory a-arms do. Bolting to the bottom your are relying on the just the welds of the tabs. But it seems that you would be lowering it by bolting to the bottom. Hope that clarifies what I mean.
Reason I ask is I really value your opinion and experience.
Thank's
Chuck,
You are absolutely correct, and that being said, rather then recommending that others pay closer attention to the pictures or explanations, I should be doing so myself.
The tabs are welded as you stated to the underside of the a-arm, and my guess is that it's done this way in order to keep the same stroke on the shock as on a factory A-arm. Were the weld-nuts on the top as factory, there would be a reduction in the stroke of more then 1/2" .
All the welds on these arms being done with what look's like multiple passes with the tig welder, I doubt very much if these tabs would ever separate from the arm. However if ever one needed to reinforce the mounting, and at the same time defeating the lower weld tabs issue, it would be very easy to use slightly longer bolts, and then use a flat washer and a nut on the other side of the A-arm shock mount, thereby locking it firmly in place.
This might just be something that I will recommend VBP to mention in their installation manual. As it stands, I went over the installation manual for the front A-arms, and as strange as it may seem, the only mention of shock absorbers is, and I quote ( " reinstall shocks " ) unquote. I guess they think their two words would be self explanatory. :ugh
Thank you for bringing this to my attention, as I also value your input.
Stepinwolf
